I have a 883 Sportster, 2009 model.
Without going into details of how and why, the bike ending up sitting, (stationary with alarm in transport mode), in 500mm of water for 6 hours – to put this in perspective, this is sufficient to completely cover the starter motor. (and lots of other things)
I have been working through the bike now for some 2 weeks and believe I have covered EVERYTHING with the exception of one thing which is to establish whether any water got into the sump.
(As you will be aware, these engines have what I consider to be one very poor design flaw, which is whilst a dry sump engine, there is no facility to actually drain the sump.)
I removed the oil pump, (amongst many other things obviously) in the hope of being able to insert a small vacuum pipe along the scavenge circuit gallery in the crankcase half, but this proved unsuccessful.
Obviously the water did manage to access the gearbox/primary drive cases through the breather pipe which is just forward and below of the stater motor, (this is now all drained and cleaned out following removal of the primary drive casing cover) – but….
COULD WATER GET FROM HERE INTO THE ENGINE?
I note that there is a crankshaft oil seal on the primary drive side of the engine, (which I obviously see as a good thing), where as there is none on the timing cover side, (Note: There was no evidence of water in here upon removing the timing cover.)
I’m obviously at the “start it and see” stage but beforehand, I thought I’d reach out for any comments on this.
Yes, I know, there are many "focused" Harley Sportster platforms out there but as this has always been my "go to" forum, I thought I'd post here first.
