davidsuffolk
I have a SIP 50 litre V twin 3hp direct drive compressor which is not working properly.
In truth it has given me more than my fair share of problems so I have put it on eBay as a non runner though it does work, just not correctly.
What happens is this. It starts fine and pressure builds but as the pressure climbs air starts to leak from the oil filler (there is a pin hole in the dip stick) until when it gets to about 80psi it is really strong and starting to lift the whole dipstick. If turned off tank pressure holds and the leak stops.
I have replaced both head gaskets and the reed valves seem OK but it seems that somehow the crankcase is getting pressurised.
Any knowledgeable members any thoughts on where the problem might be?
