My welder was only a cheap one and as such the duty cycle (think that's what you call the heat cut out) is pretty sweet not helped along by me being pretty bad at arc welding.
Having gained some tips and pointers from this forum i intend to start using the welder again later this week for some more practise.
I had some old computer fans knocking about so thought I'd stick them (literally) in the welder to see if it helped the cooling any and save me spending as much time waiting for it to cool down.
This modification is ropy to say the least and it was only half way through that I thought about taking the pics and posting it up on here.
I'm a sparky by trade so I know how to avoid getting electrocuted (most of the time)
but to avoid getting the blame for any fried hair DON'T OPEN UP YOUR WELDER IF YOU HAVE NO COMMON SENSE OR DON'T KNOW WHAT YOU'RE DOING
Always isolate the supply and perform the safe isolation procedure but even then there are components in electrical equipment that can kill you when not plugged in.
anyway, on with the procedure, I took the cover off and wanted to stick the 2 fans on top of each other covering the entire back vent but there wasn't enough room with the iron bar when it was cranked up to full amps so had to put them next to each other at the bottom of the vent.
the 'cowling' is an ice cream tub cut to size
The fans are 12v so the mains power needs to be stepped down to safely power the fans. I used the transformer out of one of those battery charger plugs giving me 12v DC 500mA
using some very strong double sided foam pads the 12v tranny stuck in position
for strength and integrity i always solder wire connections in things like this using thick heatshrink sleeving
The power for the 12v tranny is taken from the switch so the fans run whilst the thermal cut out has cut power to the welding tranny.
Fans in situ
complete ready for the cover
I bent out the vents to try and give more flow
Back together and ready to rock
Testing the flow with a lighter (don't try at home, i had no smoke matches) i was surprised at how much air they pulled through the box.
I'll let you know if it helps any or if it was a complete waste of time.
I had all the stuff and the process took 30-45mins from start to finish. The only electrical protection to the modified circuit is the 13amp fuse in the plug top, bear this in mind if you feel compelled to try this modification, I ain't being held responsible if it burns down your garage or workshop
Fans in situ
