Hi all, new to arc but used mig before, my question is regarding metal thickness with arc welders.
Been looking at 300 amp welder with a stated max of 12mm then found another at 500 amps and stated the same max of 12mm.
Whats the max thickness I can weld with a 300amp arc welder?? Also would this 12mm max sugguest I can weld a 90 degree Tee joint with two 12mm sections or two 6mm to give a total of 12mm
Also many have a chance of a 9-10 Kva generator would this run a 300amp arc manual on welder states 9Kw input.
Many thanks
Jools
Many thanks
Jools
