Becasue of the curves and I'm going to be working at angles, does anyone know the best way to fillet weld two pipes of 30mm*1.8mm mild steel.
When flat at 75%/low angle using 2.5 6013 rods. Filed materials etc and clamped etc. Should I do 1/4 fillet welds and rotate to keep slag flowing downwards whilst moving upwards etc? Worried about breaking whilst doing this because I will still have to remove slag?
Its for a hobby project/frame etc, I'm very new to this. I can weld in a straight line but find connections not being made. Even with thicker materials.
Round pipes are what I am working towards. The rods I have are "SUPER 6". Anyone used these, are they ok? Working at 70 to 80 amps as too much spatter if too high. Only an ARC WELDER 100 by SILVERLINE being used, seems ok to use as I could layer for thicker metal, but my hobbies are only based around thin metals about 2.5mm max. MILD STEEL used also.
Any method idea's for small things like this are appreciated, thanks.
