Hello everyone,
I initially was going to buy a MIG Clarke 160TM, but have since realised that it probably won't be ideal for me to do work in the field or on the "thicker" stuff.
I've got a 3T Mini digger with steel tracks. One of the chain links have snapped, so would like to weld it back together. A few have already been welded together successfully by the previous owner.
My question is, will an arc welder do it? (Are they also called Buzz boxes?) If so, what sort of welder should I be looking at. I don't mind buying secondhand. I've never welded before (hence the reason I was going to give MIG a go). Will need to weld things like estate fencing at a later date. No work required on thin bodywork etc.
Hope that makes sense to you all...
Thanks
Thanks
