Guys and Gals,
As you're a bunch of very clever people with a lot of experience, I thought I'd air my latest problem and hope that someone has got a solution.
I've recently bought a garage door opener off eBay (£33 - kerr-ching!
). It's an old Henderson screw type. I've tested it and it works. So last night I proceeded to fitting it. After a few minor issues I got it fitted in the ceiling. It's not perfect, but it sits there quite nice and snuggly. The door moves up and down just "fine".
Now here's my problem:
When the garage door is at the topmost position, it's in a "notch" to keep it up. As in, if you push it slowly up, just before the end, you can feel it going into a notch that keeps it up. Naturally when the motor tries to push the door down, it can't do it because the door is in this "notch". There's no way I could push it down, well possibly with a hydraulic jack between the top of the door and one of the rafters in the ceiling. Not ideal.
How do I solve this? Can I get rid of the "notch"? How light (easy to open/move) does the door need to be to be able to use an automatic door opener?
Any help appreciated - I think I've got most things solved apart from this; closing the door.
I'll have a look what door it is when go out to the garage.
Thanks for all your insight and help!
