I got my nvq level 1 and 2 in 1994/95 and got a job welding for a few years. After that I ended up on the building sites and haven't touched a welder untill last week. I actually forgot how to use it and kept getting the rod stuck!
I'm wanting to make a set of gates for the side of my house and have a few questions. First is - how do I stop getting the rod stuck to the metal. I know this sounds silly because I should know but I've been away from it a long time and its like starting all over again. I've tried high- low settings but couldn't weld it right
My house is an old stone house rendered and I'm wanting to make a set of gates that's between mine and the next door negibours which is also an old stone house rendered. The measurements between the 2 houses is 1.3m wide and want the gate 2m high.
Is it possible to set the gates in box section that's not bolted to either house. Don't want to break into tge plaster and stone walls in case it beings damp through.
What size materials should i use for the gate and box section where gate will be attached to.
