I'm getting on a bit
- London UK
So thought maybe time to join.
To say hello everybody and join in the fun
Morning!
Mornin fella
What's the worse that can happen...
Welcome aboard.. What are you planning..?
Sounds good I like tig welding.Hi Richard ive been reading tig welding threads. Mild steel pretty easy. done some stainless "external corner" .6mm using a pedal started with the amps too high but did a short run autogenous "not too bad"
But ali is a different ball game finally worked out where i was going wrong "torch angle" too low so melted the filler before i got it in the puddle done a couple of autogenous external corners that are not too bad at all
I'm thinking of getting a tig pen
Autogenous Alu doesn't really work too well most of the time due to it's nature of running away. Have you got your own machine
