brewdexta
The biggest tool in the box
- UK
The motor on my mill had been swapped out for a bigger motor and the original pulley had been bored out. I have refurbished the original motor and want to put the original 3 way pulley back on. There is not enough meat in the pulley to use a taperlock bush so will be turning a sleeve, wall thickness will be approx 4mm.
Looking at the size of the old and the new they are probably 5/8" (circa 15.9mm) and 15/16" (circa 23.7mm) respectively and it needs to be just over 2" long. The mill motor/pulley is identical to
I will be cutting 2 key-ways in the sleeve and one in the pulley, not the full 2" and opposite sides of the sleeve. There is a grub screw in the smaller pulley.
I have both brass and aluminium rod handy, but will have to buy in some steel. If ali or brass is no good, what grade of steel is better for turning/boring?
Cheers
Andy
Cheers
Andy
