ardwood.com
New Member
Hi guys.
I work with wood and metal and I am making a project using 6mm mild steel bar. To give an idea it may end up like a spiders web.
I wish to weld the bar in different configurations ie. a tee shape Y shape a v shape etc.
I have an old arc welder buzz box which works well enough when I get it going.
After a discussion with a friend we came up with the idea of a scratch plate to get the arc going then move on to the joint. Works a bit, but not always practical.
An ideal situation would be to use what I already have as I like it well enough but sticking is a problem and if I turn up the amps to get around this it can blow holes or eat to far into the end of the 6 mm bar leaving an etched effect weld.
have tried pre heating the rods in a slow oven and I use a very heavy blue, arctic cable, extension lead to supply power to the machine.
I have thought of buying an inverter stick welder but is that ideal for this type of job.
Any help would be very welcome.
Cheers Alan
Cheers Alan
