Chesterfield250
New Member
- North Yorkshire
Hi,
My first post, my first small step into the world of welding.
I received my welder today, its an Esab Buddy 180 MMA/TIG Inverter.
I wanted something that would be portable for a few small jobs and is certainly not getting used for anything more than hobby.
My dad has just retired from a lifetime of welding. He started as an apprentice in the shipyards, moved to structural welding (buildings and things) then to agricultural vehicles and finally retired while working in stainless steel fabrication. He is very experienced and if I could be 1/10th as good as him, that would be just fine.
While I could ask my dad to teach me to weld, and at some point I'll no doubt want to learn from his experiences, I really want to start out on my own... making my own mistakes and learning from them.
So today I found myself unpacking the little yellow welder and plugging it in.
I grabbed the only bit of metal I had to hand (about 10mm), stuck a 6013 2.0mm rod in the holder, set the amps to the rod recommended 55A, and went to work.
I had no idea how quickly rods get eaten, looks like I'll be ordering more this week :-0
The first pic is of just a few beads I did first (never picked up a welder till today mind, so go easy on me:-( )
I worked from right to left.
The first line I thought was maybe done a bit fast, so I slowed it down for the next two lines.
It made no difference, so remembering something I read online in the tutorials I figured I maybe needed more Amps. So I stuck it up to 80A. Instantly realised it was too much as it splattered all over for the first 10mm of the next bead, so I backed it off to 65A. I then seemed to get a lot better welds.
The last few beads I found the slag was just peeling off on its own, so I hardly needed hammer.
Last bead (single pic) I dropped the Amps to 60A.
My question is;
On the last few beads, I seem to get penetration but am wondering if I am going too slow now, given the quite wide and tall bead.
Any advice would be appreciated, and hello :-)
My question is;
