Park_monkey
Hello all.
I am in the process of doing a few improvements to my garage and need a bit of advice on what to do with the roof.
It is a prefab concrete panel job with an angle iron frame and corrugated tin sheet roof (not asbestos). It is all a bit battered to be honest as it was second hand when I bought it but it will have to do.
My main issues with it have always been the fact that the roof is too low, the terrible condensation and the lack of security, so I have started making it a bit more useable.
I have already extended the uprights by 800mm at the front sloping down to 500mm at the back by cutting them in half and welding a piece in the middle. These are now refitted and the roof support crossmembers bolted to them, I have put the roof sheets back on but not fully secured yet. I have a load of insulation and used plastic coated lining sheets that I plan to line the inside walls with, which should tidy it up and make it a bit more secure, as well as a bit warmer, but I'm not sure what to do with the roof.
The tin sheets are a bit scruffy and full of holes where they have been drilled before but I can't really afford to replace them and don't want to end up with the same condensation problem. I did consider fixing a thin layer of ply on top of the sheets then felting but wasn't sure if the cavity left between the ply and tin would cause problems. I was thinking about taking the tin off and fixing timbers the length of the garage then putting ply and felt but I'm a bit concerned about the weight. So would it be possible to felt straight on to the tin sheets? Or can anyone suggest another option? I can't afford to throw a load of cash at it but at the same time i want to get it sorted while I'm doing the work anyway.
I was going to insulate the ceiling against the tin and plaster board the ceiling to try and stop the condensation.
So any suggestion folks? Cheaper the better, I'm all ears.
I do have a few pics of the garage if it helps, I've probably not described what I'm doing very well.
Cheers.
Cheers.
