Hi all, been a long time lurker and used the information on here to kit out my garage! So thanks for that!
Now to my problem in hand, I have an infill panel on the back of my van I would like to fit, the part itself is in GRP (moulded plastic or whatever you want to call it) and it will need bonding / blending into the existing metal panel.
Is it as simple as just sanding the paint with 240grit, bonding it in with sika or tigerseal then applying a layer of filler to blend? (then paint) Or will that crack?
Here are a couple of pics to help explain!
This is the part in place
This is just the infill on its own
Any help would be much appreciated! Stu
