A (possible) cunning plan popped into my head a few weeks ago, and ive just seen the main component advertised cheap and local.
Whats the opinions on using/converting an IBC container to a blast cabinet?
The biggest problem was the need for a frame for the IBC.
The one I used had had the top cut off and it was just too flimsy. I made a wooden frame to go into the hole but it still wasn't great.
It's only around £20 for a 8'x4' sheet, so wouldn't be much difference between that and buying/transporting an IBC.It was the type with the frame/cage. Thought if i'd cut the openings and if necessary, fixed onto the cage to improve rigidity.
Not all do.
The pallets get sold on their own. We've got 8 of the pallets and 2 of the IBC's themselves.
Wood is a much underrated material these days, IMHO.
it'll be interesting to see how well they cope once a water pipe has burst and soaked them into mush.Hardly surprising when you see the quality that is on offer at the usual suspects.
Got some batten timber from Wickes last year, (their timber generally tends to be of a slightly better quality than the B&Q stuff), to make a fence and gate for the side of the house. To say it was an experience would be polite. Had to use wedges at some of the joints before tightening them up, to counter for the warp in the wood. Sod's law though, they got a batch in a week or two later which was straight as a die.Then there's those fabricated 'joists' made from papier mache and the sweepings from a coffin-shop floor...it'll be interesting to see how well they cope once a water pipe has burst and soaked them into mush.
Our 2-storey office suite at work is built using them and the floor has more flex than a 6th-form girls' gymnastics team...
)be ok if u skin it with sheet steel or rubber liningNot sure of wood for a blasting cabinet. I think it would get eaten alive internally by the grit?
Julian.
