matchless_mike
I have recently bought a 20g blast pot off Ebay and am using it with Sealey B/25KG bags of grit (0.2 to 0.7mm) along with a Clarke 14cfm 150psi compressor.
The problem I seem to have is that it appears that the grit does not always flow through the grit valve at the bottom of the blast pot - leaving me just blasting air ! Tipping the pot back and forth and trying to give it shake sometimes gets it working again. I have tried varyng the amount of grit in the pot from as little as 12kg but with no improvement. When I empty the pot I don't see any evidence of a blockage at the bottom - just the ball valve.
I do sieve the grit before use and let the pressure in the pot build up to over 100psi before use. Any suggestions/solutions appreciated !
