probably best to use paint stripper 1st then blast them over depending on your compressor size and what nozzle u are using on your blast pot and what pressureI have a question I want to strip the paint on some alloy wheels In a effort to hide some marks I painted direct over the wheel with about 3-4 coats.. Anyways will wallnut shells work of the coarse type? The grit number is 12
Any reason why to strip first instead of blasting?
correct and it depends on what gear u are using . blasting at 90 psi using a 6mm jet at 90cfm soon removes coatings . anything smaller takes a fair timeTo minimise the amount of blast cleaning required would be my thought.
