Ok folks, I'm new here and just wanted to get an opinion on the state of the valve on my BOC-supplied Argoshield cylinder shown below. With the regulator in place and tightened (not too much) there is a substantial leak at the joint to the cylinder. The regulator nut sits proud by about 7mm when tight and if you look into the neck of the cylinder there seems to be a small crack.
(1) Is, as I suspect, the crack most likely to blame?
(2) Does the regulator need any sort of sealing washer where it joins the cylinder?
(3) If the crack is to blame what are my chances of getting BOC to replace the cylinder
I've had the cylinder three weeks now, the first regulator leaked in the same way so I treated myself to the one shown (with the same leaky results). Only then did I inspect the valve to find the crack.
Any input much appreciated.
Tom
Tom
