All,
Finally fed up with the lack of capacity my 6-gallon (oil-less) compressor provided, I recently bought a used 5hp 33-gallon craftsman. I bought it off a chiropractor who said he didn’t use it very much and who knew less than I do about it—which is not saying much. He ran it for me for ~30 seconds when I bought it, and it ran well.
After the hour-drive home, I unloaded the unit and plugged it in. It ran well for about 5 minutes, but then something happened and it really started to run poorly; it sounds like it’s getting bogged down, like the motor is having a hard time driving the compressor. I loaded a short video on youtube here: http://www.youtube.com/watch?v=p-toEKTBkLE
The only thing I can tell you that it seems to be losing a good amount of oil out of the bottom gasket, which appears to be shot. I noticed it was even spraying a little bit of oil as it ran while it was running well. This seemed bad, but I’m not sure whether it’s the cause, related to the cause, or unrelated to the cause of the problem.
I’m pretty comfortable with engines and taking things apart (I rebuild old motorcycles), but I don’t know anything about air compressors. If someone could please give me some idea as to what this problem may be and how I troubleshoot it, I would appreciate it.
Thanks in advance – I appreciate any thoughts.
Thanks,
-s
Thanks,
-s
