rosinante
- Cornwall England
Good morning Illuminati,
Having an issue with pressure loss on my Grant oil combi boiler I decided to isolate the heating system by allowing the boiler to cool overnight then closing the output valves to the radiator circuit and repressurising the system , put 2 bar in and the pressure fell before my eyes, while the covers were off I noted the air hose for combustion was disconnected from the flue, J reconnected and then returned valves and pressure to normal and started the boiler, the burner fired right up and then cyclically faded and relit, so I believe air starvation , disconnecting hose restored normal combustion , so two issues, flue and pressure loss , the pressure vessel was replaced in April of this year and a boiler service conducted.
Can the flue be cleaned out on the intake side? It is vertical and about 5 metres maximum length, pokes out of the roof of our bungalow, fairly accessible , advice on this most welcome, it looks very similar to that sold in Screw fix, cream coloured outer with clipped joints. Then there is the issue with pressure loss , can't get a boiler tech anytime soon , all to busy , should add we are both to old to be getting on a roof , guidance welcome
Thanks in advance
Chris
Thanks in advance
Chris
