bigegg
- Leeds, West Yorkshire
I have a mountain bike.
Very expensive new, but i got it stupidly cheap because some muppet had hammered the wrong size seat post into the seat tube, then cut it off level.
Theres about 10 or 12 inches wedged inside. 22mm ID, 26mm OD (inner tube) and its an alu frame, alu seatpost.
Its been an ongoing project for 3 or 4 (or 6!) years, and i want to get it either sorted, or abandoned.
I've tried heat+cold to break the (assumed) corrosion - in conjunction with a slide hammer. It never budged.
So. I went for more destructive measures.
I drilled down the end of the tube starting with a step drill to keep it centred, then with a 25mm TCT "hole saw". Which drilled out the first 3 inches, leaving a narrow sliver which will easily remove.
I then ordered a 25mm blacksmiths drill and (using a hosepipe to keep the frame cool) managed to get about 8inches down before it bottomed out, still leaving four inches stuck solid: which *still* wont slide hammer out. (I'm using a piece of m24 all thread, made into a tap and welded to the slide hammer).
The TCT hole saw is the chinese type like a forstner bit, not like a core drill, and worked really well, compared to the blacksmiths bit.
So...
I need an extension which will take a 10mm drill shaft - with grub screws to lock it in place (rather than a hex, which would be easy) and be 250-300mm long so i can drill out the last few inches.
Or another idea...
So...
Or another idea...
