Hello guys,
Im new to this forum and have spent a couple of evenings trying to establish a spec for a blasting pot I want to build, Ive read lots of threads on here but still a little unsure. My reason for build rather than buy is I have the skills and equipment to make a good job and Im lead to believe that the cheap ebay or Machine Mart pots all benefit from some improvements anyway so if Im going to tinker I might as well tinker properly!
Ive got a 15kg Butane pot so thats my starting point.
Firstly, I have a 3hp 150L 13CFM compressor which seems quite small for blasting and would limit me to a 3mm nozzle or so Ive read?. I have an option to buy another compressor of the same size, will running two in tandem make a noticeable difference, if so in what way?
Will two tougher shift rust and paint faster or will they just have to work less than one? not really sure how two will be better than one?
Onto the pot, for the air inlet into the pot and then down to the media valve should I run 1/2BSP fitting or bigger/smaller?
I saw a grit valve thread that looks interesting and would be easy enough to make.
Any suggestions on what to expect from my compressor set-up or advice on my blasting pot build would be gratefully received.
