Satashooter
New Member
Hello all,
I'm looking for some input on an idea that popped up in passing conversation the other day.
We were on the subject of various tools, and a friend mentiond seeing years ago on a farm, an old boy had been tinkering with afew Ford 1.8 non turbo diesel lumps. He had a couple running on trollys and benches and was using them for a generator, and apprently in some fashion an air compressor... Friend seemed to think it was being used to power a blast pott as well!
This got me thinking... I'm a sprayer by trade and although my compressor does a decent enough job of supplying my air fed and a gun, it lacks abit with a DA, but I use an electric one anyway. I certainly wouldnt pass up more CFM's. The idea of being able to power a blast pot is appealing to say the least!
Has anyone ever come across this being done, with any engine?
I gave it some thought, and the only real problem I can see would be having to alter the valve timing slightly so the inlet and outlet valves opend at slightly different times. After all a diesel engine is built to run incredible compression, it seems totally feasable? If the size of the pistons in my pumps are anything to go by as well, the bottom end of an engine would really chuck out some CFMs. Further thinking... if this is possible, why not use a smaller diesel generator engine (with smaller pistons) for a 2nd stage as well? With abit of head scratching and working out, with the right ratios...
Anyone have any thoughts, or even doing this them selfs?
