As per title, im going to put one together.
Loose plan is, i have a large extractor fan. Designed for use on roof of industrial building. Fan is circa 2 ft diamter with a serous motor attached. I used to use it at my old place mounted in the wall when spraying. It moves some serios air!
I intend to mount it on a pallet and build a box effectively, so i can spray components (bits of car), with the air being pulled through from the front, through the fan and out through a filter.
Or may be with filter in front of the fan. Not sure?
Something like this, but for £50, not £1500! https://www.ebay.co.uk/itm/Alloy-wh...117580?hash=item2f3c89a90c:g:rKoAAOSwh0BeIEKd
My main unknown, given 2K will be involved and it wont be exhausting to outside all the time (sometimes it will) is what filters. Clealy i need a primary spray booth filter, but not clear what charcoal/carbon filter i should be using behind this?
Thoughts?
Thoughts?
