I want to buy a compressor for paint, pressure testing, inflating tyres (mtb tubeless)...etc. Paint will be limited to smaller parts and panels; Ill leave the big stuff to the professionals and I dont want to spend over £300. The Burisch BT-390T seems the same as the Wolf 90 litre air compressor (doesnt seem avaliable anywhere). The BT-390T spec seems better than the Draper. Anyone knows of an other/better option?
I was looking at belt driven due to noise so it seems odd that both Burisch units are the same noise level which is odd? FAD ( Free Air Delivery ) spec seems lacking on the Burisch BT-390T, anyone know?
Burisch BT-390T 90 Litre 3HP Belt Drive Air Compressor
https://gtair.co.uk/air-compressors/1-burisch-bt-390t-90-litre-3hp-belt-drive-air-compressor.html
£264.99
Air displacement: 14.1CFM
Motor: 3HP
Tank Capacity: 90 litre
Max Pressure: 10bar (145psi)
Noise level: 97dB
Dimensions: 985mm (length) x 870mm (height) x 440mm (width)
Weight: 85Kg
Burisch BT-3100V 100 Litre 3HP Direct Drive Air Compressor
https://gtair.co.uk/air-compressors/8-burisch-bt-3100v-100-litre-air-compressor.html
£229.98
Air displacement: 14.1cfm
Motor: 3HP
Tank Capacity: 100 litre
Max Pressure: 8bar (115psi)
Noise level: 97dB
Dimensions: 1060mm (l) x 400mm (w) x 780mm (h)
Weight: 63kg
Wolf Air Compressor 90 Litre 150PSI Belt Drive 3HP 14CFM Twin Cylinder Pump 240v
Air displacement: 14CFM
Motor: 3HP
MWP 150psi (10BAR)
9.2cfm free air delivery
Draper 100L 230V 3.0hp (2.2kW) Belt-Driven Air Compressor 31254
http://mccormicktools.co.uk/draper-...MIj6Ky4dLj3QIVYrXtCh2HLQRNEAQYAyABEgJfRvD_BwE
Tank Size 100L
Motor 2.2kw (3.0HP)
Air displacement 11.7fm (330L/min)
Free air delivered (FAD) 8.1cfm (230L/min)
Input current 13A
Speed 1100rpm
Maximum pressure 116psi (8bar)
Sound pressure level 77dB
Sound power level 79dB
Dimensions 1090 x 430 x 860mm
Weight 75kg
This 100L Belt-Driven Air Compressor (2.2kW) can be found on catalogue page number 629.
This product weighs 63.80kg.
£264.99
Motor: 3HP
Noise level: 97dB
Weight: 85Kg
£229.98
Motor: 3HP
Noise level: 97dB
Weight: 63kg
Motor: 3HP
MWP 150psi (10BAR)
Tank Size 100L
Motor 2.2kw (3.0HP)
Input current 13A
Speed 1100rpm
Weight 75kg
