Hi
My neighbour where I work does metal fabircation (beams, structures etc etc) and he is having all the staff tested. I don't know what the test is called I will find it out tomorrow for you when they get in.
They are having issue with the weld cracking when tested and aren't sure what they are doing wrong so I suggested to post it on here for them just trying to help them.
10mm mild steel
1mm wire
35 degree vee
2mm gap between joints
they are using about 190amps on a cebora mig
see the fracture
Fracture
Same piece
After welding
How it looks after welding
Profile
Bottom of the weld
Just some testing of welds etc but you can see the workpiece
Any ideas what is wrong guys? If you need more info let me know and i'll find out.
Thanks
10mm mild steel
1mm wire
35 degree vee
see the fracture
Fracture
Same piece
After welding
Profile
Bottom of the weld
Thanks
