Stereophoney
Welding Novice Grinding Expert !
I've got a propane powered calor gas heater in my garage which at the moment is in constant use, problem is it's not kicking out much heat and makes a noise like there is something blowing on the flame
The only thing that gets rid of this is picking up the cylinder and shaking it, this stops the noise and the fire brick glows redder, but only for 3 or 4 minutes, then back to before, it' seems it's being starved of gas and i can't use it on the higher settings or it gets worse, there are no loose connections on the regulator and hoses.
It's really starting to get on my t*ts now, could the propane be freezing ? it is - 7 in my garage, i'm all out of ideas
Any ideas would be gratefully recieved
Cheers Gary
Cheers Gary
