Bought this old compressor last week.
I'm not sure if it's on the original base but most of it appears quite old. It has had a new motor fitted, I might fit an older motor so that it looks more period.
I want to strip the pump & give it a check over. There is some leakage into the sump when it's warm so I suspect some ring or bore wear. I would like to ID the pump so I can check on the availability of spares. Here are some pics.
The only markings I can find is 'No 8450 London'
I tried to remove these 2 plugs which I assume give access to the valves - not a chance, even with a 3' breaker bar!
I think this is a water trap, it has a nice brass drain valve on the bottom.
