Reman
- Bristol, UK.
Pretty much as the title says.
I finally got to grab my "Proper" compressor out of my sisters garage (It's been blocked in with household crap after one of her friends downsized and piled the rest of the garage full of the junk they didn't have room for.......... FOR 8 YEARS!!!!!
). It's a reasonably chunky industrial Clarke Air unit with a 160L tank.
When I bought it second hand it had a 4hp 3 phase motor on it. Didn't have 3 phase so I put a 4hp single phase on it, But that drew so much current that it ended up needing it's own power line running to a new RCD in the fuse box. The garage I have now isn't attached to the house and it would be a huge b*** ache getting another dedicated spur out from the fuse box, So I'd rather not have to go down that route.
I seem to remember that this thing could pressurise the tank way faster that any of the tools I used could empty it, So I'm now toying with the idea of replacing the motor with a 2hp unit so I can power it off one of the garages existing 3 pin sockets, But running a smaller pulley to under speed the compressor a bit to give the motor a bit more leverage over the pump when it's getting up to pressure.
In my head it all seems like a perfectly reasonable workaround to the problem, But I'm not too headstrong to assume I might have missed something (Almost too headstrong, But not quite.
So, Is there something I'm not seeing? Could running the pump slower damage it?
If it's all gravy, I'm wondering, As I'll have to get a different pulley anyway, Would a 2800RPM motor and an even smaller pulley be better than a 1400RPM unit? I'm thinking the faster motor speed is going to be carrying more momentum and that could help as the tank fills up and the pump get's harder to turn, But would a 1400RPM unit have considerably more torque?
Alternatively, I've still got the 4hp 3 phase motor kicking about, If I ran that off an inverter (A technology I'm shockingly unknowledgeable about) could it be made to "Soft start" to lower the start up power spike enough to be ran off a mains socket? Would that be a cheaper option? If that's possible, How would I wire an inverter to the pressure cut off switch?
). It's a reasonably chunky industrial Clarke Air unit with a 160L tank.When I bought it second hand it had a 4hp 3 phase motor on it. Didn't have 3 phase so I put a 4hp single phase on it, But that drew so much current that it ended up needing it's own power line running to a new RCD in the fuse box. The garage I have now isn't attached to the house and it would be a huge b*** ache getting another dedicated spur out from the fuse box, So I'd rather not have to go down that route.
).So, Is there something I'm not seeing? Could running the pump slower damage it?
) that the difference in Amp draw Vs power output can be quite noticeable with different quality's of motor. Cheap motors tend to be less efficient, and the manufacturers have a habit of rounding output figures up (Sometimes by quite a scandalous margin). I'm trying to compare 2 and 3hp motors from different manufacturers to see if any are worth a closer look to work out if some really are more efficient, Or if it's just bull **** marketing.
