Hi,
What is the grit capacity of a 20 gallon sandblaster like this one on Ebay UK item number 281390961318
Do I fill it right up, or only 2/3, 1/2 full whatever?
Cheers.
I think I have looked on Ebay before and their prices for a 25 Kg bag are certainly cheaper but I can't see any 80-120. The books and videos I have commonly refer to 80-120 grit for glass etching and carving. The Machine Mart tubs have 80-120 on them, so does that mean the grit size is a mix from 80 up to 120? On Ebay I see AO available in a mesh size of 80 but not an 80-120 mesh. This mesh size I find a bit confusing could you explain please?
Machine Mart does have bigger 20 Kg tubs but works out more than the 7.5 Kg ones.
They have a large tub designated as 60-80 and another as 60?
Thanks.
Mesh size refers to the number of holes per linear inch in the mesh used to sieve out the grit during manufacture. 120 mesh is 120 holes per inch, so the higher the number the finer the grit.
The actual size of the hole in the sieve will be slightly smaller than 1/120 th of an inch due to the thickness of the wire.
