I have a Abbey Spectrum 620, about 1991, I at the weekend(land rover show) was trying to get the three way fridge to run on gas, never tried it before, nearly all the time we pay for hook up.
This is a three way fridge so it can run on 240v, 12v or gas, for the gas it has an auto ignition, ie don't have to keep pressing Prezzo, switch on to gas and it should start, but the light on the ignition is suppose to flash when trying to light and it don't.
So back home, took the sink out to get to the top of the fridge, can see the mains going in, can see the 12v, and I can see the 12v for the ignition, (both have a poss and Neg) put a meter across the two 12v feeds and I have power at the ignitor, but not at the 12v.
My question is can I run a 12v Poss across to the 12v (the neg works fine).
I am assuming the 12v feed needs power to run on 12v but am guessing it also needs to have 12v to run on the gas? but I might be wrong.
Now the other problem is this model of caravan was suppose to have a magic box Macs 5/12 which is a transformer. The box is under the seat I have checked to see if the fuses are ok, and they seem ok only 2! there is another fuse, by a connector I have checked that and that seems ok, but there does not seem to be any other 12v fuses, looking in the hand book that seems right, but to me the transformer, is sat at the front of the caravan under a bench and the battery and mains power is behind the rear axle double axle), there are trips for mains (in a consumer box).
