Pretty obvious.......'still have' says it allsorry to say that means very little above
all youve said is what model and that youve replaced the transformer for some reason we dont know
we dont know what happened
why you changed your transfomer
what conclusion made you think it was that part
what tests that you did
Why?After having transformer on PCB replaced (which looks like someone who has just picked up a solding iron for first time) I'll have to scrap it.
No output from small transformerWhy?
Are you now getting an output from that small transformer?
When you press the torch trigger, does the 24v relay on the PCB operate?
Does the main welding transformer power up? Is there any AC and DC output from it?
If you extend the MIG wire from the torch tip and press the trigger, can you strike an arc?
Just had transformer replaced to remedy this and I still have no wire feed
If there is no output from the 27v AC transformer after you have had it replaced, I would suggest that you ask for that work to be repeated, successfully this time.No output from small transformer
No 24v to back of motor when trigger pressed
Yes
No
