Replace the liner. May be steel or nylon depending on what torch is fitted. Steel's best in my opinion and you can usually modify a standard 3m liner for this - cut off the brass fitting, gently grind off any burrs from the leading edge and push it as far as it will go. Make sure you don't cut it too short at the machine end - it should almost touch the rollers.
