HI was hoping someone could advise on the following problem with an old Cebora 852 mig.
The torch is remaining live in use, the gas solenoid remains on , the Contactor Relay remains on to when turned on. The wire supplying the smoothing capacitors from power setting switch was badly corroded/overloaded .
I have done the following to try to repair, checked pcb visual, replaced white power control relay , replaced euro torch connector, cleaned and checked wiring checked operation of contactor relay seems ok , removed cap bank from welder.
The fault seems to be remain and be the same no matter what u do with it. Any advice will be very helpful with this welder as it is a very good little machine thanku again .
