Hi everyone,
First post of mine ... I'm usually on here looking at tips etc.
Today's problem:
Turned the MIG on pressed the trigger, no wire was fed through the tip - you could here the machine click and wanting to turn. So, I pulled through 300mm of wire and tried again. Machine click then ceased operation.
Only test I've done so far is to change the plug with a new fuse - the problem persists.
Any quick fix i.e. folk had a similar experience? is is this a case to fault find (((
Many thanks in advance.
Karl.
Today's problem:
Karl.
