I was given a Cebora K810 from a forum member of a motorcycling website i use, it had the usual problem with the broken feed roller scenario.Here is the first image of the missing feed roller tension arm.
So an idea was born.
The end of the bar was slotted and bent carefully with a blowlamp and a hammer.
And a quick mock up for alignment purposes.
Out came the Oxford Mig. bzzzzzz
followed by the tap n die set
Nearly done...
The finished article.
And here are a couple of test welds.
That was a piece of 6mm steel plate with the 4mm gas pipe wrapped in ptfe tape and rammed into a bit of 6mm plastic hose with the wife keeping it together whilst i welded.
So ive put some castors on the base and it seems to be very good so far!
Thats the front panel.
You know when you think," i wont throw that out, it will come in handy some day" well all i did all day was use up stuff destined for the bin. Well chuffed !
Happy days, i hope that helps somebody ! cheers Pauly!
Nearly done...
