I have an old Cebora 130 Pocket Mig, which I got new over 30 years ago of Snap On. I've decided to get it up and running again after about 10 years of no use, feeds wire ok, gas valve and torch Ok, cleaned the earth clamp etc. It does weld but has no power what so ever the weld just sit on top of 1 mm steel even on full power. If I measure the Open Circuit voltage between the torch and earth clamp and I get 19,22,24 and 28 DC volts on the 4 setting. But when I weld it drops to around 11 volts when on full power across the torch and earth and 30 amps measured using a current clamp on the earth cable. Checked the AC side of the rectifier and can see the AC voltage change with the 4 position of the 2 rocker switches on both inputs to the rectifier, Checked each of the diodes individually, and they all work correctly with the multi meter. Measured voltage drop across the contactor, torch main lead and earth lead and no significant drop. I have bypassed the main contactor too but no change. Any thoughts what else to check and or I am missing something else.
Graham
Graham
