Fuchs915
New Member
- From Kent, living in Essex
Having bought a used Cebora, fitted some new parts, I want to start playing with it, so am starting on the set up. Are there any tips on getting the wire feed set up correctly? When setting the tension, is this done at any particular speed setting or doesn't it matter? I know I don't want the wire feed motor to slip on the wire, but once I have it not slipping, is that where I leave it set or is it like some nuts on cars that you set and then give a further 1/4 turn? I have some old CO2 that I will be using for the gas set up (probably more questions to follow on that!) and then I'll switch to Argon/CO2 for the actual welding.
Any other tips most welcome.
Cheers
Kevin
Cheers
Kevin
