Hi Guys,
I've finally got around to recomissioning an old cebora 880 I bought many years ago. I've fitted a new liner, tip and wire but anytime I try to weld, the feed roller slips even when on the tightest setting. I've degreased the feed roller and the tensioner above it, I've cleaned out the v groove on the roller with a fine file but it has made no difference. Once the roller starts to slip the wire burns back to the tip and that's that! The torch seems to work best when almost straight and the wire feeds fine until i start to weld then the issue occurs.
So the questions are, wouild it be worth my while upgrading the tensioner mechanism to one like this
or sourching the feed roller the welder is supposed to come with for aluminium welding and hope that it grips better.
OR, is it all my fault for not being able to weld properly!!
Thanks.
Torq
Thanks.
Torq
