Hi - got a BOC Migmaster 130 - AKA Cebora Turbo 130 - which I'm in the process of converting to Euro torch after accidentally breaking the original . . .
I've fitted the socket and wired it up and everything works so far. The last step is to add a solenoid-operated gas valve. I already have a suitable valve salvaged years ago from a gas tumble dryer which went belly-up but I'm struggling to know where to connect it into the electrics in the welder. It's a 240V coil so would need to be connected to somewhere that is normally off but energised on pulling the trigger, hence my need for a circuit diagram.
A Google search reveals diagrams for later models but not mine - so can anybody help please?
My other idea would be to connect a high resistance relay coil across the wire feed terminals and use the relay's contacts to switch the mains supply to the solenoid valve . . .
