mark williams
- Wrexham
Will the wolf 90 do it ok with 14.6 cfm?
ir drill easy grinder they use a lot of air and you would be better of using else tric grinder why run a 2.5 kw motor when half or less will do the same job not to mention they freeze your hands
Ah die grinder missed those 3 letters when I read itDie grinder? better off with a compressor which will run many tools and the tools are cheap as chips in comparison.
But ye wear gloves. Gets really cold when i'm porting
I would personally go electric, I never use my air grinder or air polisher always electric even use an electric DACorrect snooper, i was told that to run a tool by air rather than by electricity is 9 times more expensive. As well as the huge amount of cold air you dump into your work area, and the noise.
dremels are a waste of space, diy only, like most things of that size, give them any real work they heat up and die a sudden deathair tools every time. Lighter, cost less and have finer control. My Dremel died the other week, air die grinder bailed it out.
but what were u trying to do with the dremmel . overload it no doubt .i have one and i also have air die grinders . both have there uses.air tools every time. Lighter, cost less and have finer control. My Dremel died the other week, air die grinder bailed it out.
air tools over a dremel they just don't have any good power, do you cringe when you use itI've got a mini air die grinder too, sounds like being at the dentist. Great bit if kit, the Dremel couldn't compete. Way cheaper too
