What are these likely to be like? Cheap tat or good value?
https://m.ebay.co.uk/itm/10X-100W-L...curity-Light/263325915606?hash=item3d4f7299d6
I want four for a barn, the others would likely get used in the other barns at some point. That would be, if they were any good. A forum member has sent me a link to some that he's used with success though. More expensive, but a better buy.
https://www.tlc-direct.co.uk/Products/LTUSF100CW.html
For using in a barn, and only needing 4, I'd suggest going with the cheaper ones. They should be fine and you'll have spares if they aren't. I work for an LED lighting company but we can't come close to competing with that price.I want four for a barn, the others would likely get used in the other barns at some point. That would be, if they were any good. A forum member has sent me a link to some that he's used with success though. More expensive, but a better buy.
You can get LED bulbs that go inside normal 500w floodlights from Screwfix & Toolstation.
High bays, low bays and floodlights are industry standard terms for the more heavy duty types of light fitting. We will outline the main differences and uses below.
High bays are designed to be used in very high areas (approximately 8m and greater) to provide well distributed and uniform light for open areas. The key element of the fitting which will help guarantee the correct light output is the reflectors and optics used by the fitting. A particular consideration for use with a high bay is if it can light vertical surfaces as well as it can illuminate the floor, or working plane. Lighting of verticals is particularly important when dealing with warehouses where items are required to be picked from a shelf. High Technology lightings preferred high bay solution is the Insignia INV.
Low bays work in much the same way as a high bay, but will be best suited to lower mounting heights. The main differences will be in the lamp types selected and the types of reflectors and optics used. An example of a low bay fitting is the Insignia INM
Flood lights are a very versatile method of illuminating areas where a conventional mounting arrangement may not be an option. The flood light will have an asymmetric throw of light which can be angled into the space to be lit. Care and consideration of glare should be taken when designing with floodlights, due to the brightness of the fitting and the fact it may be angled close to horizontal.
Are those a decent solution.
I'd avoid those to be honest, all the voltage control electronics and other stuff has to be built into the bulb, and because it's all in a tiny bulb sized package heat dissipation becomes an issue. LED bulbs are great for replacing household bulbs but as you increase the output heat becomes a big problem. Definitely go with dedicated LED luminaires for something like this.Are those a decent solution.
I'd argue that a 100w LED floodlight is more comparable with a 500w halogen, granted this doesn't make the LED sound quite as good but as far as illumination level I feel it's a lot more honest.Cheap tat seems quite likley, can I ask what you want them for? 10 x 100w LED floodlights is A LOT of light. Each one should be roughly equivalent to a 1000w halogen.
Fair comment, and depending on the fitting the truth is likley to be somewhere between the two. If I have a chance next week I'll do a comparison between a 500w halogen and a 30, 50, 70 100 and 150w LED floods and measure light levels at various distances... That will depend on work being quiet though. I'd be interested to see how the facts stack up against the information I've been given.I'd argue that a 100w LED floodlight is more comparable with a 500w halogen, granted this doesn't make the LED sound quite as good but as far as illumination level I feel it's a lot more honest.
