Nomad
- North Devon (for how long?)
Hi, any suggestions why a cheap diesel heater will run but not put any heat out??
Good battery, has been primed, makes all the right noises but does nothing.
It showed error E-06 once but normally no error codes.
I have 2 identical units. heater 2 works fine.
Swapping it out for heater 1 (same controller, pump, fuel) I get some heat out of the exhaust but no heat from the output.
Threads:
Heater blows cold
There’s also a couple of threads with the larger suitcase size heaters, the one I have is more shoe-box size.
Any bright ideas ??
Threads:
Heater blows cold
Diesel heater blowing cold
Not used for a couple of weeks, this morning it seemed to start fine. No error codes. After a while I did not feel any heat. Went outside, pump is silent. Just the main fan seems to be running. As I say no errors. Is there simple way to test the pump or maybe fix it. I understand it's quite a...
www.mig-welding.co.uk
Any bright ideas ??
