chrisniknikki
New Member
right here we go got a clark warrior 30 compressor bought as faulty is 110v
just borrowed a step down transformer to test it plugged it in turned it on motor turned half a turn then stuck if i turned fan at back by hand it did the same then took off air pipe to tank switched on and it ran slowly at first then up to full speed put air pipe back on it filled tank to 20psi then started to run slow let all air out did the same but now it not running to full speed any ideas whats wrong cheers
