Sidney Rough-Diamond
Hi,
Friend has offered me one of these for nothing if I want it as he is clearing out his garage and knows I mess about with cars.
I have a couple of car projects on the go at the mo and was wondering if this gun could be of use. Basically I have a number of cast aluminium parts such as throttle bodies and the like that could do with blast cleaning to restore them. I also have a few steel parts that are lightly corroded and could also use some blast cleaning before a dip in one of those DIY zinc plating kits.
What I would like to know is what media will work best with this gun for cleaning aluminium parts and the steel parts, will it simply take anything ?
Also, looking at glass abrasive for sale, there looks to be a couple of types, one is around £27 for 25kg and the other larger at between 0.2mm and 0.7mm for around £7 for 25kg. Can anyone explain the difference between the two in what they should be used for ?
Not being able to have a compressor at home, I'm able to use a large compressor at work ( 60cfm ) that I can outdoors if needed ( it's located in a sand quarry ) , so air supply shouldn't be a problem.
Thanks for any help
Thanks for any help
