landsendsolo
New Member
Hi
Hoping someone can point me in the right direction.
I have a SE36c270 Air Compressor that has a pump fault, I have stripped it down and it looks like the valves need replacing so will change the piston Rings and gaskets at the same time. Had an air leak into the piston shaft casing. Should I cahange the valve plate as well or is this not required, Clarke sell the valve plate with the valves for £75 + Vat.
Anywhere other than Clarke that will sell these spares, I been doing google searches but cant find any suppliers.
Any help appreciated.
Thanks
Les
Thanks
Les
