Submariner1
- Berkshire
I need to Cleanly drill 8mm Holes through a 25mm deep (dense rubber) Ice Hockey Puck.
(Changing to bigger rear wheels) so need to raise the front AV Pads)
anyone ever drilled this kind of material?
- only ask as I don't have any spares, so would rather know before; if one needs any special type/profile of bit?
- Is this better drilled at high speed or low speed. I assume low speed? To avoid melting or will that grab rather than cut?
Only got a small pillar drill and usual HSS steel drill bits, and some cobalt drill bits for stainless.
the discs to be drilled are in photo below under the wheels.
