bucko Member Messages 306 Jan 24, 2009 #1 Is it possible to clear coat over polished milled steel? thanks
madkayaker Pro sparkey Pro Welder Messages 13,678 Jan 24, 2009 #2 can't see why not what you got in mind?
bucko Member Messages 306 Jan 24, 2009 #3 I’ve made some pedals and they look to good to cover up with paint I’m going to post some pics of them in projects in a sec Just wasn’t shore if it would bond to a smooth surface
madkayaker Pro sparkey Pro Welder Messages 13,678 Jan 24, 2009 #4 the surface will be smooth to touch but rough on a larger scale (hope that makes sense)
bucko Member Messages 306 Jan 24, 2009 #5 yep it dose once i have the spacer welded on il give it a go
T TVT Member Messages 33 Jan 24, 2009 #6 Yes you can. mist it on first to give it a key, then it`ll go on fine. The actual pedals themselves might be a chellenge, as the clear will wear off in fairly short order.
bucko Member Messages 306 Jan 24, 2009 #7 yeh but it will nomater what coating i use wish i made them out of stainless now lol
madkayaker Pro sparkey Pro Welder Messages 13,678 Jan 25, 2009 #8 the top of the peddle will wear off but so will the rust!
