wristpin
Often have to work on lawnmowers where alloy cutting spindle housings are held to steel deck pressings by 3/8" "taptite" self tapping screws. Steel screw + alloy housings + years of corrosion sometimes results in a sheared screw which being designed to self tap into the housing is as hard as ****!
If they shear flush with the surface can sometimes can mig a nut onto the the bit left in the housing and helped by the heat from the migging wind it out but otherwise it is a matter of attempting to drill it out.
Are the so called Cobalt (coated?) drills likely to be any better than a quality HSS twist drill and are there any quality standards for them? Equally does anyone have any alternative suggestions (other than don't shear it in the first place!!!)
