Paul99
Been getting fed up lately of using the 25l compressor so thought I'd dig out the big jetair compressor from the back of the shed which I rescued from a scrap man years ago for parts as it was assumed broken. Anyway after fitting a new motor I find that it pumps but clearly there is something very wrong as it just doesn't build any pressure (rises very very slowly to about 10psi then builds no further no matter how long it's left.
I've sorted out the check valve with a new washer just to eliminate the simple things first and bypassed the pressure control valve temporarily just to eliminate that too. I'm now thinking that it must be worn piston rings (probably why it might have been scrapped all them years ago) - I can quite easily hold by thumb on the end of the air output pipe whilst running and suction is not all that great on the intake either to my mind.
I took the head off and cleaned the reed valves off but all seems ok and can't see anything obviously wrong above the pistons. There appears to be no lip at the top of the cylinder so hopefully a case of new rings and new gaskets. I assumed that there would be service kits easily available but no - half an hour of google ing and looking on ebay has thrown up a blank this far so does anyone here know of a source of parts for this compressor pump?
Hope someone has some ideas...
Paul
Paul
